FS: PSI built Haxo Sounds (Crystal Audio) 15" driver
Inferno333
Haxo Sounds motor (Crystal Comp CompX2)
PSI recone with 6" carbon fiber cap
Sundown Zv.2 Dual 2 flat aluminum coil
The Qts should be in the .45-.48 area now since it's fully broken in.
Revc = 3.7352 ohms
Fms = 27.0610 Hz
Zmax = 58.4594 ohms
Qes = 0.5483
Qms = 8.0334
Qts = 0.5133
Le = 3.2529 mH (at 1 kHz)
Diam = 330.2000 mm ( 13.0000 in )
Sd =85633.5536 mm^2(132.7323 in^2)
Vas = 160.1271 L ( 5.6548 ft^3)
BL = 16.1444 N/A
Mms = 225.0298 g
Cms = 153.7136 uM/N
Kms = 6505.6050 N/M
Rms = 4.7628 R mechanical
Efficiency = 0.5438 %
Sensitivity= 89.3722 dB @1W/1m
Sensitivity= 92.6799 dB @2.83Vrms/1m
Used - Very good condition
Minor rub mark on the surround
Wood/Paint stuck to the gasket
I would say 8/10 cosmetic and 10/10 function.
$200+shipping
got any other pics?? How much clean rms power can this take daily??
What kind of pictures are you looking for?
It has an aluminum Zv.2 coil in it so it's not going to break a sweat with 1500+ watts of clean power. The best part is that it doesn't require an absurd amount of power to get loud. It's really efficient.
Inferno333
Inferno333
Nebraska
Inferno333
