FS: PSI built Haxo Sounds (Crystal Audio) 15" driver
Inferno333
Haxo Sounds motor (Crystal Comp CompX2)
PSI recone with 6" carbon fiber cap
Sundown Zv.2 Dual 2 flat aluminum coil
The Qts should be in the .45-.48 area now since it's fully broken in.
Revc = 3.7352 ohms
Fms = 27.0610 Hz
Zmax = 58.4594 ohms
Qes = 0.5483
Qms = 8.0334
Qts = 0.5133
Le = 3.2529 mH (at 1 kHz)
Diam = 330.2000 mm ( 13.0000 in )
Sd =85633.5536 mm^2(132.7323 in^2)
Vas = 160.1271 L ( 5.6548 ft^3)
BL = 16.1444 N/A
Mms = 225.0298 g
Cms = 153.7136 uM/N
Kms = 6505.6050 N/M
Rms = 4.7628 R mechanical
Efficiency = 0.5438 %
Sensitivity= 89.3722 dB @1W/1m
Sensitivity= 92.6799 dB @2.83Vrms/1m
Used - Very good condition
Minor rub mark on the surround
Wood/Paint stuck to the gasket
I would say 8/10 cosmetic and 10/10 function.
$200+shipping
Inferno333
Inferno333
Nebraska
Inferno333
