FS- Profile 640sx (Old School Blue) and Exile S400.4 4 channel amps
  • 5
casper97ta
IM HERE FOR THE GANG BANG
A profile 640SX and Exile Audio S400.4 4 channel amps
Both amps work great, the Profile I'd rate about 7/10, There are some scuffs and scrapes. The Exile 8/10, again just some scratches. Both amps work perfect. I just removed the Exile from my truck. I was using it and My Alpine 9887 to run active. The exile is a great amp with lots of crossover options and plenty of power. The profile is a basic 4 channel that will get the job done.
$100 obo shipped for the Exile and $50 shipped for the Profile
prices are shipped
They actually are known to do close to rated power, Here are the actual specs:
2-, 3-, or 4-channel output
Tri-way capable (Tri-Way crossover required)
75 watts x 4 into 4 ohms
110 watts x 4 into 2 ohms
225 watts x 2 in bridged (2-channel) mode
requires 4-gauge power and ground leads — wiring and hardware not included with amplifier
continuously-variable high-pass and low-pass crossovers (40-130 Hz at 12 dB per octave)
2-ohm stable in stereo
gold-plated high-current cable inputs for maximum current transfer
continuously-variable (0-12 dB) bass boost at 45 Hz
105 dB signal-to-noise ratio
two 30-amp fuses
13-3/4"W x 2-3/8"H x 9-13/16"D
There is the 16pin connector in armrest of my old mercedes 2006 S350. Any possible way I can stream music from my phone wirelessly(Bluetooth) or...
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
The dirtiest hooker allive gotta smell better than fried Epoxy! (okay, that was a tad bit nasty, but funny nonetheless!)
casper97ta
casper97ta
Pittsburgh, PA
casper97ta
    May 31, 2024
    May 24, 2024
