Sold FS: Powerbass xa3000d
PowerBass XA3000D
Specifications Model XA 3000D
Number of Channels 1
Output Power (14.4V) @ 1 ohm 3000 watts
Output Power (14.4V) @ 2 ohm 2000 watts
Output Power (14.4V) @ 3 ohm 1000 watts
Frequency Response 10 Hz - 400 Hz
Total Harmonic Distortion 0.05%
Signal to Noise Ratio @ 100Hz >90 dB
Input Sensivity 200mV - 6V
Dimensions (W x H x L) 10.51" x 2.56" x 20.87"
Benched at 2800w+ at 12.3v at 376 amps of draw at 1 ohm stable load. At 14.4v, 3500w. At 16v, 4000w. Drop the impedance and you start getting ridiculous power. This beast weighs 30lbs. Only a handful of amps actually put out more power, all for a lot more money.
PowerBass XA3000D
Wow that is some immense current draw...
Think I would be good for a daily driver with a 200A alt (already have the alt)?
Big three will be done, and yellow top under the hood... If needed, I'll add a second yellow
Bump for a killer amp. Phat Toney, i think these will run at .7 but you have to have the elect. sys. in order to do it. Check out termpro i know guys were running them strapped at that load, so ask around there. This will put out more than rated power as well......
hehe, it's no problem bud. I just wanted to try, that's all I have to spend on another one of these. If you do want to or whatever, I can do $375 shipped out, total. Just let me know if you wanna do it sooner or later bud. Thanks.
Oh and just to let ya'll know. You can drop these amps down to half an ohm, I do it with my amp. And I have heard they will run down to .35, you just need the power as foreman said.
bumpn_gt
bumpn_gt
Columbus, WI
kw_rock
