FS: Polk DXI 104 4 ohm
03TL_TypeS
Polk DXI 104
Used. Only reason I am selling is because I am taking on a new hobby so cars and audio will not be part of the new hobby.
Diameter 10" (25.40cm)
Type Dynamic Balance polymer composite woofer
Electrical
Total Frequency Response 28-200Hz
Nominal Impedance 4 ohms
Efficiency 86 dB
Power Handling
Continuous 270 watts
Peak 540 watts
Voice Coil
Driver Diameter 2" (5.08cm)
Thiele / Small Parameters
Resonant Frequency 35 Hz
Xmax
Xmax Linear 0.622
SD 54.25in/2
VAS 0.99ft/3
QTS 0.55
QES 0.59
QMS 9.1
Dimensions
Cut-Out Diameter 9 1/16" (23.02cm)
Full-Range Mounting Depth
Top Mount 5 7/16" (13.81cm)
Bottom Mount 5 15/16" (15.08cm)
30 + Actual Shipping
Shipping will be by the buyers choice, Fed Ex, USPS, UPS
03TL_TypeS
03TL_TypeS
Nor Cal, CA
03TL_TypeS
vegang
vegang
