Sold FS: planet audio line driver... cheap
Twisted_0912
1. Product: planet audio pld2 line driver
2. Specs:
High Performance Signal Processor
2 Channels in/2 Channels Out
Low Level Inputs and Outputs
Variable Output Level
Remote Power On/Off
LED Peak (Overload) Indicator
LED Power Indicator
Pulse-Width Modulated (PWM) Power Supply
Frequency Response: 10Hz to 3 kHz
Max Output Level:8V RMS
Signal to Noise Ratio: 85dB
Channel Separation: 60dB
Input ImpedanceL 20 K-OHMS
Idle Current: 100 mA
Power Supply: 10-16VDC, Neg. Ground
Fuse Rating: 3A
Dimensions: (WxLxH) 11 3/4" x 7 3/4" x 2 1/4
3. Description/Condition: looks and works great. this is a great addition to a system that has a low volt pre out headunit. makes the signal clearer and you dont have to crank the gains as much to get the rated power out of your amp
4. Price: :
20 plus shipping
5. Pictures:
Twisted_0912
Twisted_0912
NE ohio
Twisted_0912
