Sold FS: Pissload of Audio - RF, TC Sounds, Aura, Boston Acoustics
donpisto
I need to get rid of these things since I don't use them. Prices DO NOT include shipping, because it will vary on location (I'm not going to try to make a profit on shipping). If more pics are requested, I will take some. I have many refs on several forums, way too many to list, and I will provide upon request. Also, since 10 images is the max per post, some will have links to pictures rather than the direct image.
1. 12" TC Sounds TC9
2. 15" TC Sounds TC9
3. Four 10" Focal 10V1
4. Aura Force A-340 amplifier
5. Rockford Fosgate 500a2 amplifier
6. Boston Z6 speakers (mids and tweeters)
7. Enclosure for 15" Sub
This sub is brand new minus maybe 5 minutes of play. It is a single 4 ohm driver and I do have a box to match it, but I'd rather not ship the enclosure since I don't know how expensive shipping would be. Enclosure is 1.13 cubes before displacement and is 14 x 14 x 14 (IIRC). It is sprayed on the interior with rubber undercoating and stuffed with fiberglass insulation.
Pictures:
Price is $175 for the sub and add $40 if you want the enclosure as well.
This one works just fine and it is a Single 4 ohm driver. It has a couple minor dents in the cone, which DO NOT affect performance at all and the surround has a hole that needs to be fixed (I just haven't done it yet. I can include RTV Silicone sealant so you may do it yourself). This also DOES NOT affect performance in any way.
Pictures (The bottom sub):
Price is $175
3. Four 10" Focal 10V1 subs
I have four 10" Focal 10V1 subs. They are all Single 4 ohm drivers. Specs on sub are located here: http://www.zalytron.com/pdf/10v1.pdf
Pictures: (I will get a picture of all four together shortly, for some reason it wasn't on my PC).
Price is $90 each or $315 for all four.
4. Aura Force A-340
Only specs I know is that the amp does 170x2 @ 2 ohms (not bridged). These amps are underrated from what I have heard. I bought this a while back, but never used it. I did power it up to make sure it works and it does.
Pictures (Don't have external picture, but will take one shortly):
http://i5.photobucket.com/albums/y178/donpisto/0909070927.jpg
Price is $150
Here is an oldschool amplifier. It does 125x2 @ 4ohms, 250x2 @ 2 ohms, and 500w x 1 bridged at 2 ohms. This amp is also underrated and I used it to push a DD9515 and it got pretty loud (136.8 on the TL in a trunk setup). I recently took out one of the screws, but will need to find it. There is another one that got stripped so it will not be included (unless I find something at Home Depot or if anyone knows where I can get one). It will come with the end caps as well.
Pictures:
http://i5.photobucket.com/albums/y178/donpisto/IMG_1710.jpg
Price is $125
6. Boston Acoustics Z6 mids and tweeters
These come from the Z6 component set. I changed mids and the tweeters I had bought BRAND NEW and are NEVER USED. The mids are 6.5" and the tweeters are 1" Titanium tweeters. Please do not ask about crossovers as they are sold.
Pictures:
http://i5.photobucket.com/albums/y178/donpisto/0804070755.jpg
http://i5.photobucket.com/albums/y178/donpisto/0804070757.jpg
http://i5.photobucket.com/albums/y178/donpisto/IMG_2088.jpg
Price is $200 for the mids and tweets. (Tweeters alone cost $140 from Boston Acoustics)
I built this to use for SPL with my DD 9515 but never got a chance to use it since it didn't fit in my trunk once the sub was mounted. . I will double check the volume as well, but I believe its 4 cubic feet. The ports are two 6" pipes and can be cut to desired tuning frequency. The pipes alone cost just about $13 each from Home Depot.
Pictures:
http://i5.photobucket.com/albums/y178/donpisto/0619072135a.jpg
http://i5.photobucket.com/albums/y178/donpisto/0620072116a.jpg
http://i5.photobucket.com/albums/y178/donpisto/0621071803.jpg
Price is $50 (Local pickup ONLY - So Cal area)
If you have any questions please feel free to ask.
Thought I'd make it easier for you guys, here are the pictures (those with links)
4. Aura Force A-340
Pictures:
Pictures:
Pictures:
TTT for teh feggle
Thanks bish.
really nice stuff you got here
Thank you sir!
bump for a good guy
Thanks Brian //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
are the Boston Acoustiz Z6 brand new?
Partly. The mids are not new. I bought them used on ebay and was going to hook them up in my Accord, but they needed more power (HU ftl), so by the time I got an amp, I decided to go a different route. They work great.
The tweeters, however, are brand spankin new. I bought them directly from Boston Acoustics since I planned on using them going active with the mids, but as mentioned, I ended up changing my mind.
donpisto
donpisto
Los Angeles, CA
dragnix
