Sold FS: PHOENIX GOLD xenon 200.4
smd4life
NOTHING ABOUT MEADE
hello everyone i have a PG xenon 200.4 i'd like to get rid of, does 200x4 @ 4-1 ohms, bought it form blados about a week ago, and am going a different route...works perfect 10\10 250 shipped
thanks
RMS Power @ 4-1 Ohms: 200W x 4 @ 14.4V
Bridged RMS Power @ 8-2 Ohms: 400W x 2 @ 14.4V
Signal to Noise Ratio: > 100 dB
Bass Boost: 0 - 18 dB
XeTUNE- Advanced input and signal processing circuitry
Top-Mounted Controls
24 dB / Octave Crossover
Twin-T Variable 0 - 18 dB Bass Boost at 45 Hz
Auxiliary Outputs Route Full Range Signals
Tri-Linear Capability Allows Simultaneous Stereo and Bridged Operation
XeFlow- Thermal feedback system with output optimization
Bottom-Mounted Extruded Aluminum Heatsink
Expanded Metal Mesh Intake & Exhaust Vents
Ultra-Quiet Variable Speed Fan
Temperature Monitoring with Automatic Output Optimization
Superbrite 5mm LED Power Indicator
XeLOAD- Full power with automatic load sensing
Load Sensing Optimizes Power Supply and Output Stage
Maximum Power Output From 1 - 4 Ohms Stereo or 2 - 8 Ohms Bridged
High-Current Triple Darlington Output Stage
150-Volt, 15-Amp, 60 Mhz Sanken Output Transistors
Direct Insert Speaker Terminals Accept Up To 8 Gauge Wire
4 Gauge Power Terminals with Removable Rubber Grommets
Dimensions: 22 W x 10.6 L x 2.5 H
Someone needs to buy this. This is an awesome amp. It's underrated and puts out a ton of clean power. You can't get any better for the price.
im working on it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
and you are right this amp is a real power house it pushes out 200rms a channel with such ease.
i have 1 already would like another because they are so good
Exactly. And it's shiny //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
too bad i changed it from that set up.
my install after that was with 2 kicker l7 15's
my new install is going to be 4 phoenix gold rsd 10's in about 7.5cf after port and sub displacement. when i had the new set up graphed there was almost a 11db peak at 20hz!!!!!!!!! and about a full 6 db peak all the way up into the 50hz's.
its looking like its going to be a hit you in the chest bass set up, not as loud as the kickers were but definantly will be hitting some seriuosly low bass notes.
ill be throwing 2 phoenix gold xenon 1200.1 and the 4 subs. it wil be a nice set up, cant wait to finish it up
And you're buying this 200.4, right?
yes a deal has been reached.
i honestly wont be using this amp right away, i just try to pick up as many of the xenon series brutes as i can. this series of amps are killer.
look at this x200.4 it has all the bells and whistles, it has seperat highpass and low pass crossovers for each side (front and rear) it can be run in bandpass mode. it has bass boost for each side also, it has the option 2 or 4 rca input and 2 aux outputs, dual 4 guage power inputs bridgeable, can run in 2,3, or 4 channel mode. this thing has 24 output fets!!!! dual fans. it has every option you can ever want, 1,2,3,4 ohm load a monsterous heatsink on it that the fans are hardly on, actuall output is closer to 1000rms (all channels driven)
probably one of the best SQ sounding amps i have come across.
so know i have all these xenon amps
x1200.1
x1200.1
x200.4
x200.4
x400.1
and am always looking for more of them
i also have a few other phoenix gold amps.
M44
ms275
mps2240
and other random PG gear
teq215x 15 band eq
tidd 10 remote turn on system
tba1 line balancer/driver
pld1 line driver
ti elite 6 inch compnent set (made by morel)
2 sets of xenon x5 compnents ( being shipped to me)
and soon to be 4 10 inch rsd subs
yes i am a phoenix gold fan
go home, you don't belong here.... and did you get a chance to send out the LD? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif needs to be getting another 600.1 here to try the MEMO mod :p ...
and you need to quit debating on subs, I didn't want to say it on sb so I wouldn't get hated on but my RSD 12" is in like 2.5ft^3 55hz 65in^2 port :p . sounds decent, it was actually a test box I never took out after metering lol. anyhow if you need to sell me something else lmk on the PG forum //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
gave to secretary to ship out for you, you are in good hands.
im not going for spl with this set up , my box will be tuned to something like 27 or there abouts, going for low bass notes, you know the ones that hit you in the chest
smd4life
NOTHING ABOUT MEADE
smd4life
TN
slc720052
