hello everyone i have a PG xenon 200.4 i'd like to get rid of, does 200x4 @ 4-1 ohms, bought it form blados about a week ago, and am going a different route...works perfect 10\10 250 shipped
thanks
RMS Power @ 4-1 Ohms: 200W x 4 @ 14.4V
Bridged RMS Power @ 8-2 Ohms: 400W x 2 @ 14.4V
Signal to Noise Ratio: > 100 dB
Bass Boost: 0 - 18 dB
XeTUNE- Advanced input and signal processing circuitry
Top-Mounted Controls
24 dB / Octave Crossover
Twin-T Variable 0 - 18 dB Bass Boost at 45 Hz
Auxiliary Outputs Route Full Range Signals
Tri-Linear Capability Allows Simultaneous Stereo and Bridged Operation
XeFlow- Thermal feedback system with output optimization
Bottom-Mounted Extruded Aluminum Heatsink
Expanded Metal Mesh Intake & Exhaust Vents
Ultra-Quiet Variable Speed Fan
Temperature Monitoring with Automatic Output Optimization
Superbrite 5mm LED Power Indicator
XeLOAD- Full power with automatic load sensing
Load Sensing Optimizes Power Supply and Output Stage
Maximum Power Output From 1 - 4 Ohms Stereo or 2 - 8 Ohms Bridged
High-Current Triple Darlington Output Stage
150-Volt, 15-Amp, 60 Mhz Sanken Output Transistors
Direct Insert Speaker Terminals Accept Up To 8 Gauge Wire
4 Gauge Power Terminals with Removable Rubber Grommets
Dimensions: 22 W x 10.6 L x 2.5 H
thanks
