I have two for 300 for the pair or 180 for one shipped!
They are mechanically 10/10
Looks one is
9/10 can tell was a little used
the other is 8/10 has a small worn look about an 1" long in the longer black part.
Only used for about 3-4 months at 2 ohms
Rated power output
----RMS power, 4 ohm stereo
125W x 2CH
----RMS power, 2 ohm stereo
200W x 2CH
----RMS power, 4 ohm bridged
400W x 1CH
Signal to Noise Ratio >90dB
Low pass frequency crossover 50Hz ~ 5KHz
High Pass Crossover 30Hz ~ 3KHz
Variable Subsonic Filter 10Hz to 500Hz
Bass Boost 0~18dB
Variable Bass-Boost Frequency Control 35Hz to 120Hz
Frequency Response 10Hz ~ 40KHz (+/-1dB)
THD@RMS Watts
Channel Separation 75dB
Fuse Rating 20A x 3
Input Sensitivity Variable 200mV~6V (+/- 5%)
Dimensions 252(W) x 58(H) x 340(L)mm
Willing to trade for kinetik 2000 battery or alpine pdx 150.4
pics will be up later tonight
Looks one is
Rated power output
125W x 2CH
200W x 2CH
400W x 1CH
Bass Boost 0~18dB
THD@RMS Watts
Fuse Rating 20A x 3
