Recently picked these up, but found a better deal the next day so need to sell these.
Both work and have been tested.
Need anymore information please ask //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
MTX Thunder 5302 2 Channel Amp - $80 SHIPPED
Specs:
Power Acoustik A2400DB Mono Amp - $150 SHIPPED
Specs:
•900 watts x 1 into 4 ohms RMS, 1400 watts x 1 into 2 ohms RMS
•Full regulated PWM power supply
•4-way protection circuit, bridging synchronization
•Variable low pass, subsonic filter and subwoofer EQ
•Dual mono speaker output connectors
•Gold plated heavy duty power and speaker terminals
•2400 watts bridged maximum power handling @ 1 ohm
•15"W x 11"D x 2 1/3"HFeatures
•1 Ohm Stable Stereo
•Variable Subsonic Filter 15Hz-40hz
•Variable Subwoofer EQ @ 45Hz
Specs:
- Thunder 2-channel high-performance car amplifier featuring patented class A/B output
- 75 watts RMS x 2 at 4 ohms (150 watts x 2 at 2 ohms)
- 300 watts RMS x 1 bridged output at 4 ohms
- Xtant Technology Cooling (XTC) - Thermal-regulated turbo-charged fan intercooler
- PrizmEFX accent lighting effects - Customizable to match your vehicle's interior
- Semi-unregulated MOSFET power supply
- Overload and thermal protection
- StreetWires connection terminals
- Variable electronic crossover at 40~350 Hz, selectable 12 dB Hi/24 dB Low Mono, defeatable
- Quasi-parametric EQ, 12 dB/octave, 30~80 Hz
- A.R.C. (Active Resonance Control): Cut 0~15 dB/octave, Freq. 200 Hz
- Input (RCA connection): Low-level, hi-level w/Smart Engage
- Input sensitivity: 100mV-1V/1V-10V switchable
- CEA-2006 Compliant
- Dimensions: 16-11/16" L x 9-5/8" W x 2-1/2" H
Specs:
