pair 4x6 Pioneer TS-A4672R
work perfectly fine and selling them because they would not fit in the riviera after i totaled my skylark.
-150 watt max
- 20 rms
- 4 ohm
- 3 way
-"Open and Smooth" Sound Design
2 12in Mtx Jackhammer Jh45
had these for almost half a year already,work perfectly fine,just the ring around the top came loose a little and you may have to glue it but other than that perfect , wired each sub to a bazooka amp at 250w. They are pretty loud subs for the price. also watch peoples eyes when you say that u own a JACKHAMMER! lol......asking 130 O.b.o + shipping for both
specs
-single 4 ohm
-250 rms
-300 peak
-sensitivty- 86.8db
-1.5 in. voice coil
-48 oz. magnet
2 300w Bazooka 1300 mono block amplifiers
These amps work perfectly and have little scratches here and there but the end caps cover everything up nicely.......had them on the 2 jackhammers on 4 ohms....asking $85 o.b.o + shipping for both
Old Skool Rockford Fosgate punch 150s 2 channel
This thing can pack a punch(lol) for its size. have no use for it though and its missing some screws. $65 o.b.o + shipping
-37.5 x 2 at 4 ohms
-70 x 2 at 2 ohms
-150 x 1 at 4 ohms bridged
-TOPAZ noise-killing differential inputs eliminate 80% of ground loop noise between the head unit and the amp
-NOMAD advanced protection circuitry monitors temperature, voltage, current and impedence, and provides "intelligent" shut-down protection without limiting system performance
-*****-ana circuit designs keep voltages low and signal paths simple in the pre-amp section, for minimum distortion and maximum musicality
4 ga. Scosche ground/pwr wire strands
$45 for all + shipping
(Top)
(blue)
-3.5 ft
-14.4 ft
-4 ft.
(Clear)
- 2.75 ft.
10 ga. Rockford Fosgate ground/pwr wire strands
$30 for all + shipping
(Top Left)
(Red)
-15.4 ft.
(Black)
-2.75 ft.
8 ga. Monster Standard ground/pwr wire strands
(Middle left)
(Blue)
-12.75 ft.
-2.75 ft.
-1.3 ft.
-12.75 ft.
-8.25 ft.
(Clear)
-2.75 ft.
Street wires Distribution block
- (1)4ga input and (4)8ga. output
$12 o.b.o
Scosche ANL Fuse block
-fuses included (4-6)
-150
one of the screws i craced something at the bottom, so when you go to screw the washer on top of the fuse, once you get to a certain point the whole screw keeps spinning but just get somthing like a wrench to hold it in place and tighten it fully.
$5 w/wires or $10 w/o
pm me about any questions!
