FS: MOREL ULTIMO 122 12 inch 2 ohm
Radiospank
Morel Ultimo 122 12 inch 2 ohm.
WIll sell box too for 100 plus shipping, made of Birch and is a rear loading horn style.
Item(s) Description/Condition: Used for about 5 mos, is in excellent condition and sounds even better than it looks. I highly recommend you listen to one of these and it will define what sq really means.
Comes shipped with original box and Morel emblems for the grill and authenticity film to verify this is indeed legit.
Overall dimensions DxH 305mm (12) X 146.9mm (5.78)
Power handling RMS P 1000 W
Transient power 10ms 3000 W
Sensitivity 2.83 Vrms / 1M 88 dB
Sensitivity 1W / 1M 85 dB
Frequency response 10-900 Hz.
Cone material Carbon-fiber laminated paper
Net weight 6.7 Kg. (15 lb.)
Driver Displacement 2.6 Lit (0.09 cu.ft)
Voice Coil Diameter 130 mm (5.1)
Voice coil height 37mm (1.45)
Voice coil former Aluminum
Voice coil wire Hexatech Aluminum
Number of layers 2
Max. Linear excursion X 12.5mm (0.5) (Each way)
Magnet system type Double magnet vented
HE-Magnetic gap height HE 12mm (0.5)
B flux density B 6.4 T
BL product BXL 13.0 T.M
Nominal Impedance Z 2.0 Ohm
DC Resistance RE 1.7 Ohm
Voice coil inductance @1KHz LBM 0.30 MH
Suspension compliance CMS 0.80
Mechanical Q Factor QMS 1.238
Electrical Q Factor QES 0.49
Total Q Factor QTS 0.36
Mechanical resistance RMS 14.4
Moving mass MMS 135 gr.
Eq. Cas air load (liters) VAS 105 Lit (3.71 cu.ft)
Resonant frequency FS 22 Hz
Effective piston area SD 0.0471 m
Mounting Depth: 5.53"
600 shipped
shipped via usps parcel select or can do priority if you want to pay extra
View attachment 26547356View attachment 26547357View attachment 26547358View attachment 26547359
Radiospank
Radiospank
los angeles
Bluvenim
