I have a basicly new set of these I originally purchased to replace my home theatre tweeters but the flange was too small and previous screwholes were visible. My loss your gain.
These go for 68 each new
80 shipped for the pair.
Perfect shape except the paint by the screw holes which would be covered.
Will be packed super carefully due to the nature of the silk unprotected domes.
specs
Morel 1” textile dome tweeter
Hand coated dome
Ferrofluid cooled
Replaceable voice coils
Aluminum face-plate
Gold-plated terminals
Rear chamber
Flange 94mm (3.7”)
Cut-out Ø 73mm (2.87”)
Depth 43mm (1.69”)
Znom 8 ohm
Re 5.2 ohm
Le@1kHz 0.09 mH
fs 650 Hz
Qms -
Qes -
Qts -
Mms 0.44 g
Cms - mm/N
Sd 6.0 cm2
BL 3.5 N/A
Vas - ltrs
Xmax - mm peak
VC Ø 28 mm
Sensitivity
1W / 1m 90 dB
Nom. Power DIN 200 W
specs
Hand coated dome
Ferrofluid cooled
Aluminum face-plate
Rear chamber
Flange 94mm (3.7”)
Depth 43mm (1.69”)
Znom 8 ohm
Re 5.2 ohm
Le@1kHz 0.09 mH
fs 650 Hz
Qms -
Qes -
Qts -
Mms 0.44 g
Cms - mm/N
Sd 6.0 cm2
BL 3.5 N/A
Vas - ltrs
Xmax - mm peak
VC Ø 28 mm
Sensitivity
1W / 1m 90 dB
