Up for sale is a pair of Morel EM428 4" midrange speakers. These speakers were purchased from Madisound a while back and have never been hooked up. They are currently selling for $131.10/each, Ill let them go for $200 shipped for the pair or best offer.
Frequency response 68Hz to 5000Hz
8 ohm Impedance
150W Power Handling (DIN)
87dB Sensitivity (1W/1M)
2.1" diameter voice coil, 2 layer
3mm X-max (peak)
Fs 68 Hz
Re 5.4 ohm
Le 0.36mH
Qms 3.03
Qes 0.48
Qts 0.41
BL 5.4
Cms 0.88 mm/N
Mms 6.55g
Rms 0.86 Kg/s
Vas 3.5 liters
Sd 57 cm2
Flange diameter: 118.5mm (4.66")
Cut out diameter: 94mm (3.7")
Depth: 51mm (2")
8 ohm Impedance
3mm X-max (peak)
Fs 68 Hz
Re 5.4 ohm
Le 0.36mH
Qms 3.03
Qes 0.48
Qts 0.41
BL 5.4
Cms 0.88 mm/N
Mms 6.55g
Rms 0.86 Kg/s
Vas 3.5 liters
Sd 57 cm2
Depth: 51mm (2")
