FS: Monster Cable 2 channel
bginvestor
3 sets of Monster Cable (2 channel) 201XLN
Each are 39" in length
10/10 one owner/one install (used)
Monster Cable has engineered revolutionary cables designed specifically to stop inductively coupled noise from entering car audio systems. XLN Xtra Low Noise DoubleHelix (2-channel) and QuadHelix (4-channel) interconnects feature special twisted construction, which minimizes the loop area for maximum magnetic noise rejection. DoubleHelix and QuadHelix construction reduces inductive coupling between high current sources and low level signals - ensuring noise sensitivity reduction of 40dB compared to ordinary side-by-side constructed coaxial interconnects. The results is greatly improved music reproduction - noise free. Interlink 201XLN features dual "balanced" conductors and a separate shield for cleaner highs, punchier bass and smoother, more natural sound. I201XLN has the highest quality fine copper strandings for accurate signal transfer with minimal loss. Interlink 201XLN uses 24k gold contact RCA connectors with a heavy mass ground shell for maximum conductivity, corrosion resistance and s secure fit that won't vibrate loose. Special grips allow for easy handling. Interlink 201XLN is part of Monster Cable's XLN family of noise-eliminating interconnects and speaker cables. XLN cables eliminate inductive noise for improved sound so you get maximum enjoyment from your car stereo investment
$30 Shipped TYD
See above
bginvestor
bginvestor
Tucson, AZ
bginvestor
