Sold FS Memphis 16-MCH600
nburgart
I know I'm new here but if you need some references my s/n on ebay is the same as here. I have also sold a few things on svtperformance.com under the s/n r1wheelie
1. Product:
Memphis 16-MCH600
2. Specs:
Amplifier Class Channels 1-4: A/B, Channel 5: D
Number of Channels 5
RMS Power (4 ohms) 55 watts x 4 chan. + 100 watts x 1 chan.
RMS Power (2 ohms) 75 watts x 4 chan. + 200 watts x 1 chan.
RMS Power (1 ohm) 400 watts x 1 channel for the 5th channel (Channels 1-4 Not Stable)
Maximum Input Gauge Size 4
Total Harmonic Distortion
0.03%/0.50%
Fully Variable High And Low Pass Crossovers 40-6kHz/50-250kHz
Signal to Noise Ratio >92db/>91db
Input Voltage Range 200mv-9v
Crossover Slope Selectable 12db or 18db per octave
Dimensions (dxhxw) 7.6" x 2.4" x 20.85"
3. Description/Condition:
Used but in good working condition. All the channels work 100%. Amp is powered on in the pictures. If needed I can take a video of it playing. Amp has a few blemishes that you can see in the pictures. One of the end caps doesn't secure as tight as the other one but doesn't fall off.
4. Price:
$275 obo plus shipping
5. Pictures:
got any pictures of the subs and specs?
i can take some.
These are the old school ones. They are about 2 months old. Been running about 350 watts to them
You dont have the brithsheet with the belle do you?
RMS Power Handling : 450 Watts
Peak Power Handling : 900 Watts
Frequency Response : 20Hz - 500Hz
Sensitivity : 89.9dB @ 1W/1M
Mounting Depth : 5.75" (133mm)
Cut-Out Diameter : 11.37" (289mm)
PARAMETERS
Fs : 29Hz
Qms : 6.1
Vas : (Liters) 76.4
Qms : 6.1
Qes : .43
Qts : .40
Nominal Imp (Ohms) : 4 ohms + 4 ohms
SPL 1w/1m (dB) : 89.9
SPL (2.83V/1m) : 95.1
X-Max (mm) one way : 9
Pe - RMS : 450 Watts
Pe - Maximum : 900 Watts
nburgart
nburgart
South Hill,VA
nburgart
