Sold FS: MB quart RCE 216 components
Features:
* Set includes pair of midranges, pair of tweeters, and pair of crossovers.
* Impedance: 4 Ohms
* Frequency Response: 38 ? 32.000
* Sensitivity: 2,5dB
* Power Range: 60-130 Watts
* Crossover Frequency: 4.200Hz
METAL TWEETER HOUSING
MB Quart's new Reference 19 mm tweeter uses a metal tweeter housing. It is a direct application of BTT technology originally applied to the Q-Line tweeters. This new design encapsulates the neodymium magnet structure in a specially designed metal cooling housing. This new mechanical structure helps to remove the excess energy generated inside the tweeter?s magnet and voice coil assembly. By dissipating the unwanted heat into the surrounding environment, the new Reference tweeter offers exceptional performance, improved power handling and high reliability.
COAXIAL TWEETER SUPPORT
The new Reference tweeter support allows for rapid conversion of the component speaker elements into a coaxial system. This completely new support system offers adjustable positioning of the tweeter. By twisting the support, the tweeter can be set to three different angles, each 45degrees apart. This level of adjustment allows for the best acoustical reflection angle based upon your specific installation needs
TITANIUM DOME
As a material for tweeter dome application, titanium is ideal only if properly engineered. MB Quart has nearly perfected the use of titanium over the past 25 years. Similar to the Q and Premium tweeters, the new smaller diameter 19 mm Reference tweeter domes incorporate a composite surround material connecting the dome to the housing. This combination of dome materials reduces unwanted, out-of-bandwidth harmonics and acoustical distortion. The result is an extremely smooth frequency response and extended bandwidth for a truly musical listening experience. This is what gives MB Quart its signature sound.
RCE-216 - MB Quart RCE 216 6.5" Reference Components
Pimpprotege69
Vee dubbb
Pimpprotege69
tampa, FL
Pimpprotege69
