Sold FS Massive Audio P3000.1
snarl2004
270 shipped
I have a massive audio p3000.1 for sale. It is a little scratched up and has some sand under the plexi on the top of the amp. I would probly give it a 6/10 cosmeticly.
RMS Power Output: 3000w RMS @ 2 Ohm
Peak Power Output: 6000 watts
Frequency Response: Hz - 180 Hz
Input Sensitivity: 120mVrms ~ 5.0 Vrms
Ohm Load Stability: 2 ohm
Low Level Input: No
Built in Cooling Fan: No
Bass Control Knob: No
Dimensions: 8.70" x 2.6" x 38"
it works but it sounds like something may be loose inside im not sure i havent opened it up, very well could be a heat sync not screwed down all the way or something idk. it was like that when i bought it from the previous owner about a year ago. it does work 100% though.
make sure you have a strong charging system for this amp though. if the voltage drops below 11.5 then the amp will stop playing for a slip second then start up again. it doesnt turn off or anything it just stops playing for about 1/4 of a second, but if your voltage stays above 11.5 youve got nothing to worry about.
snarl2004
snarl2004
mass
snarl2004
BP1Fanatic
BP1Fanatic
