Sold FS: MA Audio HK4000D Amp Brand new!
Sakura
CarAudio.com Exclusive
I traded for this amp with vetkilr a while back and I never found a use for it. It's just been sitting in my closet so I finally decided it was time to do some house cleaning. The amp is brand new. The box is a little misshaped from shipping but everything else is flawless! The pictures are dated 10-30-07 because I was working with someone who had a post in the Want To Buy section, but it didn't work out. Any questions...ask away. I'm at work during the day but I'll check in here as soon as I get home. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Specs:
Product Description:
* 4000W Digital Class X Competition Mono Block Amplifier
* RMS Power @ 14.4V
o 1800W x 1 @ 4 Ohm
o 3600W x 1 @ 2 Ohm
* RMS Power @ 17.0V
o 2000W @ 4 Ohm
o 4000W @ 2 Ohm
* Temperature, Voltage & Output Level LCD Display
* Thermal, Short & Overload Protection Circuitry
* Platinum Plated Screw Type RCA Jacks
* Double Sided Black Epoxy PCB Board
* Platinum Plated Block Terminals
* Fully Unregulated Power Supply
* Stainless Steel Finish Heat sink
* Quiet Fan Cooling System
* Remote Gain Control
* Full Mosfet Circuitry
* Frequency Response: 10Hz - 350Hz
* 24dB Low Pass Filter: 50Hz - 350Hz
* 24dB Subsonic Filter: 15Hz - 50Hz
* Variable 0 - 18dB Bass Boost Control at 45Hz
* RCA Input Sensitivity: 0.2 - 8V
* Low level Input Impedance: 22K Ohms
* Damping Factor: 200 @ 4 Ohm
* 2 Ohm Mono Stable
* Dimensions: 12.4” W x 2.71” H x 25.86” D
* 2-Year Manufacturer's Warranty
Amplifier Specifications:
* Amplifier Class N/A
* Number of Channels 1 - Mono
* RMS Power (4 ohms) 2000 watts x 1 channel
* RMS Power (2 ohms) 4000 watts x 1 channel
* RMS Power (1 ohm) Not Stable
* Bridged RMS Power Not Bridgeable
* Peak Power Output 8000 watts approx.
* Minimum Impedance Unbridged 2 ohms
* Minimum Impedance Bridged Not Bridgeable ohms
* THD at Rated RMS Power 0.5%
* Speaker Level Inputs No
* Preamp Outputs Yes - 1 pair
* Built-in Crossover Yes - LP
* High-Pass Crossover Frequency N/A
* Low-Pass Crossover Frequency 50 - 350 Hz
* Subsonic Filter 15 - 50 Hz
* Signal-to-Noise Ratio >96 dB
* Channel Separation N/A
* Bass Boost 0 - 18dB(45Hz)
* Bass/Gain Remote N/A
* Fan Cooled Yes
* Fuse Rating N/A
Asking Price: $425 SHIPPED O.B.O. ***PRICE DROPPED***
I am looking for NO trades
Paypal preferred but I'll also accept a money order
References & eBay account listed in sig
Sakura
Sakura
Ottertail, MN
22mountaineer
