specs? and shipping quote to 44904
ups ground says around $20
specs:
# 4000W Digital Class X Competition Mono Block Amplifier
# RMS Power @ 14.4V
* 1800W x 1 @ 4 Ohm
* 3600W x 1 @ 2 Ohm
# RMS Power @ 17.0V
* 2000W @ 4 Ohm
* 4000W @ 2 Ohm
# Temperature, Voltage & Output Level LCD Display
# Thermal, Short & Overload Protection Circuitry
# Platinum Plated Screw Type RCA Jacks
# Double Sided Black Epoxy PCB Board
# Platinum Plated Block Terminals
# Fully Unregulated Power Supply
# Stainless Steel Finish Heat sink
# Quiet Fan Cooling System
# Remote Gain Control
# Full Mosfet Circuitry
# Frequency Response: 10Hz - 350Hz
# 24dB Low Pass Filter: 50Hz - 350Hz
# 24dB Subsonic Filter: 15Hz - 50Hz
# Variable 0 - 18dB Bass Boost Control at 45Hz
# RCA Input Sensitivity: 0.2 - 8V
# Low level Input Impedance: 22K Ohms
# Damping Factor: 200 @ 4 Ohm
# 2 Ohm Mono Stable
# Dimensions: 12.4” W x 2.71” H x 25.86” D
