Sold FS: Lightning Audio SSR2002 (Rockford Fosgate CPSR) Battery regulator and isolator
krylon
KS
This unit isolates auxiliary batteries without voltage loss and ensures proper voltage level in the primary (starting) battery by allowing charge to that battery until it reaches 12.5 volts. Once this voltage level has been established, this unit couples all batteries so they can be charged collectively. When the ignition is turned off, this units becomes a one-way gate isolating current from the primary (starting) battery from passing through to the auxiliary batteries.
  • Minimum charge voltage: 12.6-12.8 volts
  • Over current fold-back about 14.4 volts to prevent battery over charging
  • Low voltage lock out: 11.6 volts
  • Power on and charge LED indicators
  • Max charge rate of 200 amps
  • 1/0 AWG input and output
This is identical in operation to the Rockford Fosgate CPSR; more information can be found here.
Link to manual
Asking $100 + $10 Priority Mail Shipping
krylon
krylon
KS
krylon
