FS Kinetic HC 3800 Batteries - 2 Available
momofx
Kinetic HC 3800 Batteries - 2 available.
Selling these for a close friend who is moving and getting out of spl for a while. These batteries are about 8 months old and were maintained with a Kinetic Intelligent charger. This was a 155+ db Vehicle that was only burped at spl comps (we went to about 5 total) so not much REAL use on these. You can see in the pics, the voltage is at around 13.2V on both batteries even after a day and half since they have been removed from the vehicle. You can rest assured both batteries are in excellent working condition.
Kinetik High Current AGM Power Cell
This Kinetik 12-Volt Car Audio Power Cell features a sealed absorbed glass mat (AGM) design and is perfect for 3800-watt car audio sound systems. The HC3800 can be used as a replacement for your vehicles standard battery or as an additional battery to provide the extra power needed for a high performance aftermarket system. It's leak-proof design and no external vents allow this power cell to fit in most factory battery locations with no hazardous leaks.
Kinetik's KHC3800 Power Cell puts out 3800 watts with a 36 amp hour rating. This battery will resist extreme heat conditions and vibrations and is 100% sealed in a reinforced ABS plastic case. Kinetik has equipped this power cell with more plates for stronger energy density and a high voltage underload. You will love the way Kinetik batteries get your system powered up and ready to go!
Battery Features•12V High Current Car Audio Power Cell
•Sealed absorbed glass mat (AGM) design
•Can be used as a replacement for your vehicles standard battery
•Can also be used as an additional battery to power your high-performance sound system
•Perfect for 3800W car audio stereo systems
•Stores energy so you don't need a capacitor for your system
•Leak-Proof, non-hazardous design
•No external vents allow this battery to be mounted anywhere with no leaks
•Fits in almost any factory battery location
•Ultra low ESR
•More plates for stronger energy density
•Higher voltage under load
•100% Sealed and maintenance free
•Tightly packed cells
•Resists extreme heat & vibrations for ultimate performance
•Authorized Internet Dealer
•1-year Manufacturer's warranty
Battery Specifications •Watts: 3800
•Amp Hours: 134
•Weight: 87 lbs.
•Dimensions: 6-13/16”D x 11”W x 13-3/8”H
$290 EACH, SHIPPED TO ANYWHERE IN CONT. US ONLY.
Each battery will be shipped in a special wooden box and then packaged. This will ensure that they get to you in one piece! I must mention that the wooden box will probably add a few pounds to the weight, but better safe than sorry on something like this!
Payment via Paypal - confirmed name and address only.
BATTERY 1 :
BATTERY 2 :
momofx
momofx
IL, USA
momofx
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
