SOLD FS: Kicker ZX750.1, (4) 8" RE Re subs, Clarion DXZ945MP, Viper 571XV Remote Start
maldecido33
MSEE
3,021
Lubbock, TX
Just cleaning out, maybe moving onto different stuff, who knows. All prices are OBO, but don't lowball me.
(4) 8" RE Audio Re subwoofers
* Dual 4 ohms, all coils read either 3.9 or 4 ohms.
* Near flawless, a couple small scratches on the motors, nothing on the face (aside of the mounting points witch have normal wear from being mounted)
$50 shipped each, $185 for all 4.
(1) Kicker ZX750.1
* Perfect Shape, birth sheet said somthing like ~850ish power output @ 2 ohms.
$175 shipped
(1) Viper 571XV
* I opened it and took everything out, but never installed anything, so its BNIB.
Features
· 4-channel remote start/keyless entry system
· FCC-Legal Remotes - No Risk of $11,000 Forfeiture penalties per violations!
· Responder alerts you when too far away to hear it.
· Only available 2-Way Remotes with 66-bit Code-Hopping!
· Confirms commands and system status using flashing LEDs on the Transceiver
· Clone-Safe® Code-Hopping®
· Parking Light Flash
· Failsafe® Starter Kill
· Anti-Grind
· Bright Blue LED Status Indicator
· Defroster Output
· Built-in Turbo Timer
· Dome Light Supervision
· 2 Auxiliary Outputs
· Horn Honk
· Safety Shut Down
· Timer Mode
· Complete Engine Monitoring
· Anti-Grind
· Engine Checking
· High- Capacity Relay Satellite
· Voltage Checking
$145 shipped
(1) Clarion DXZ945MP
* Touch screen, really a good unit. Great shape, no trim ring or remote.
* I don't have pics ATM, but will within a day or two.
$200 shipped
This is what it looks like though:
I may add some more misc stuff later on. Keep ALL offers to pm. Thanks!
how much rms can these puppies(subs) take?
clean/unclipped power, they can take as much as it takes them to bottom out...I put 1kw on a pair and they'd reach mehcanical limits if I played them too hard. I'd say a good ~600-800 per pair would be optimal with good headroom.
818
maldecido33
MSEE
maldecido33
Lubbock, TX
Louisiana_CRX
    Jun 1, 2024
    May 31, 2024
