Sold Fs:kicker Zr360 $140 Shipped!
shallowfu
24/7 REPAIR
This is a KICKER ZR360 2 channel amp for $140 shipped.It is great condition and works great!Comes with everything amp,2 end caps,all gold set screws,org. box,birth sheet,install info sheet,some other stuff.The birth sheet is marked 544 watts at 4 ohms.It has the ZRX Subwoofer crossover module ready for bypass,lowpass or hipass!This is a plug and play amp...//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
This is a KICKER ZR360 mono channel amp for $140 shipped.It is great condition and works great!Comes with everything amp,2 end caps,all gold set screws,org. box,birth sheet,install info sheet,some other stuff.The birth sheet is marked 544 watts at 4 ohms.It has the ZRX Subwoofer crossover module ready for bypass,lowpass or hipass!This is a plug and play amp...//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
ZR's are bridgeable 2 channel amps not mono amps lol.
I thought you made a typo of zx but when I saw the pix I realised it was a zr lol.
I'm intrested but I just got a small zed amp to play with, so when it gets here I'll play with it and decide if I need another small amp for my center channel //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif late!
All measurements @ 14volts unless otherwise specified
Frequency Response (4-ohm IHF Load, 20 Hz to 20 kHz 1 kHz Ref.): +0 dB, –.8 dB
L/R channel error max deviation 20 Hz to 20 kHz: .03 dB
Phase Response (4-ohm IHF Load, 20 Hz to 20 kHz 1 kHz Ref.): +20 degrees, –43.8 degrees
Signal-to-Noise Ratio (Below Rated Output, “A” weighted): –103 dB
Distortion at Rated Output @ 1 kHz: .034% @ 400 watts
Output Power (resistive) minimum output (20 Hz to 20 kHz @ 1% THD+N, all channels driven into 4 ohms): 141.3 watts x 2 @ 14 volts; 141.1 watts x 2 @ 12.8 volts; 107.4 watts x 2 @ 10.4 volts
Output Power (resistive) minimum output (20 Hz to 20 kHz @ 1% THD+N, all channels driven into 2 ohms): 257.4 watts x 2 @ 14 volts; 244.5 watts x 2 @ 12.8 volts; 167.5 watts x 2 @ 10.5 volts
Output Power (4-ohm IHF Reactive Load @ 1% THD+N @ 60 Hz bridged): 574.2 watts
Output Power (2-ohm IHF Reactive Load @ 1% THD+N @ 60 Hz bridged): 725.4 watts
Crosstalk (Referenced to Rated Output, 20 Hz to 20 kHz): –62.4 dB
Damping Factor @ 100 Hz: 147
Voltage for Rated Output: 102 mV to 2.14 volts
Idle Current Draw: 2.3 amps
Current Draw @ 1/3 Maximum Power: 37.6 amps @ 182 watts
Efficiency @ 1/3 Maximum Power: 35%
Power-Up Noise: 10.9 dB SPL
Power-Down Noise: 11.3 dB SPL
shallowfu
24/7 REPAIR
shallowfu
WEST PALM BEACH ,FL.
ramos
