Sold FS: Kicker KX350.4
04silverz
I've had this for a couple years and now need more power at 2 ohm so time to move on. I bought this from hifisoundconnection and have had no problems with it. Great amp that puts out awesome power in a small package. Includes end caps as can be seen in the pics. There is some kind of gunk in spots on the amp so I will give it a 7/10 for looks but it functions perfect. I cleaned most of the gunk off but did not put any real elbow grease into it but I think the rest wouild come off. Just in case, I wouldn't recomend this amp for someone who is planning on having a high vis "show off" type system.
•4-channel car amplifier
•60 watts RMS x 4 at 4 ohms (90 watts RMS x 4 at 2 ohms)
•175 watts RMS x 2 in bridged mode (4-ohm stable in bridged mode)
•variable high-pass/low-pass filters (50-200 Hz, 12 dB/octave)
•variable bass boost (0-18 dB at 40 Hz) with wired remote level control
•speaker- and preamp-level inputs
•CEA-2006 compliant
•Tri-way capable (Tri-Way crossover required)
•fuse rating: 20A x 2
•8-gauge power and ground leads recommended — wiring and hardware not included with amplifier
•15-3/4"W x 2-9/16"H x 9-15/16"D
Let's start at 120 shipped. Will include original box and I believe i have the manual still.
04silverz
04silverz
San Antonio
04silverz
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
