Sold FS: Kicker KX350.4 4 channel Amp
cakman
This is a great amp for running fronts and rears. The only reason I am getting rid of it is I changed to a 5-channel amp and no longer need it. I am asking $75 plus shipping or a trade for a pair of Image Dynamics 5.25" coax CTX5 speakers.
Condition:
- Kicker KX350.4
- This amp worked flawlessly when i removed it from my vehicle.
- Item has a few very small smudges or scratches on the face. (Basic install wear and tear)
- I am missing one of the mounting bolts for the front plates and one of the remaining 3 is slightly stripped on the allen head. It works if you angle the allen wrench slightly while turning.
Specs:
- 4-Channel KX-Series Power Amplifier
- Low Impedance Operation
- SORT Protection Circuitry (Short circuit, Over-voltage, Reverse polarity, Thermal)
- MOSFET Power Supply
- KickBass: 0-18 dB @ 40 Hz
- Built-In Variable Crossover: 12 dB High or Low-Pass operation (50-200 Hz)
- High & Low level inputs
- Custom tooled gold plated connectors
- SAMS (Stereo And Mono Simultaneously) bridged mono load and a stereo load at the same time
- Cast aluminum EndKaps
- RMS Power Ratings:
- 14.4V:
o 60 watts x 4 chan. @ 4 ohms
o 90 watts x 4 chan. @ 2 ohms
o 175 watts x 2 chan. @ 4 ohms
- 12.5V:
o 35 watts x 4 chan. @ 4 ohms
o 70 watts x 4 chan. @ 2 ohms
o 130 watts x 2 chan. @ 4 ohms
- Input gain control: Low Level (170mV - 5V), High Level (340mV - 10V)
cakman
cakman
Houston, TX
cakman
