Sold FS: KICKER AMPS.. ZX550.2 and ZX750.1
tcguy85
i have a couple Kicker amps i need to get rid off. just bought different amps, so these need to go.
***first is a Kicker ZX550.2. $200 shipped to the 48 states. this amp is in mint conditions. 100% perfect!
Features:
*ZX Series 2 Channel Car Amplifier
*RMS Power
205 watts x 2 at 4 ohms
275 watts x 2 at 2 ohms
550 watts x 1 in bridged mode
*Peak Power
410 watts x 2 at 4 ohms
550 watts x 2 at 2 ohms
1100 watts x 1 in bridged mode
*Remote level control included with with 20' cable
*Stereo or bridged mono output
*4-ohm stable in bridged mode
*Tri-Way capable
*3-way protection circuitry
*Speaker- and preamp-level inputs
*Bass boost (0-18 dB) centered at 40 Hz
*Variable high-/low-pass crossover (50-200 Hz, 12 dB per octave)
*Frequency response: 20 Hz - 20 kHz
*Preamp outputs
*Two 40-amp fuses
*Dimensions: 20" x 9-5/8" x 2-1/8"
*** secondly, a ZX750.1. asking $175 shipped to the 48 states. this one was a Refurb off ebay. i'd rate it 8/10 cosmetically but 10/10 mechanically. it works perfectly fine, but just doesn't look 100% brand new.
Features:
* Mono subwoofer amplifier
* 375 watts RMS x 1 at 4 ohms (750 watts x 1 at 2 ohms)
* 750 watts Peak x 1 at 4 ohms (1500 watts x 1 at 2 ohms)
* Variable low-pass filter (50-200 Hz at 24 dB per octave)
* Variable bass boost (0-18 dB at 40 Hz)
* Subsonic filter (12 dB at 25 Hz)
* Wired remote bass level control
* Class D design
* CEA-2006 compliant
* Speaker-level inputs
* Preamp outputs
* Fuse rating: 40A x 2
* Requires 4-gauge power and ground leads 80 amp fuse recommended, wiring and hardware - Not included with amplifier
* 14-11/16"W x 2-5/16"H x 9-5/8"D
yea it is a good amp. i just needed a 4 channel for my fronts and didn't like what kicker has to offer for 4 channels and i like my amps to match. so i bought 2 new amps and just need to sell these. also i was running the 750.1 at 4 ohms, i wanted a little more power at 4 ohms. it makes plenty at 2 ohms though.
yeah it sure is possible... Thats how most people wire (2) 2 ohm DVC subs to a 2 ohm load..
Thats how I am going to do..
Unless your subs are 1 ohm DVC or whatever, then it might be a different story
I really want to pick up that kicker 750.1, wish I had the money right now //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
tcguy85
tcguy85
Hyde Park, NY
yota_fanatic
