i have a couple Kicker amps i need to get rid off. just bought different amps, so these need to go.
***first is a Kicker ZX550.2. $200 shipped to the 48 states. this amp is in mint conditions. 100% perfect!
Features:
*ZX Series 2 Channel Car Amplifier
*RMS Power
205 watts x 2 at 4 ohms
275 watts x 2 at 2 ohms
550 watts x 1 in bridged mode
*Peak Power
410 watts x 2 at 4 ohms
550 watts x 2 at 2 ohms
1100 watts x 1 in bridged mode
*Remote level control included with with 20' cable
*Stereo or bridged mono output
*4-ohm stable in bridged mode
*Tri-Way capable
*3-way protection circuitry
*Speaker- and preamp-level inputs
*Bass boost (0-18 dB) centered at 40 Hz
*Variable high-/low-pass crossover (50-200 Hz, 12 dB per octave)
*Frequency response: 20 Hz - 20 kHz
*Preamp outputs
*Two 40-amp fuses
*Dimensions: 20" x 9-5/8" x 2-1/8"
*** secondly, a ZX750.1. asking $175 shipped to the 48 states. this one was a Refurb off ebay. i'd rate it 8/10 cosmetically but 10/10 mechanically. it works perfectly fine, but just doesn't look 100% brand new.
Features:
* Mono subwoofer amplifier
* 375 watts RMS x 1 at 4 ohms (750 watts x 1 at 2 ohms)
* 750 watts Peak x 1 at 4 ohms (1500 watts x 1 at 2 ohms)
* Variable low-pass filter (50-200 Hz at 24 dB per octave)
* Variable bass boost (0-18 dB at 40 Hz)
* Subsonic filter (12 dB at 25 Hz)
* Wired remote bass level control
* Class D design
* CEA-2006 compliant
* Speaker-level inputs
* Preamp outputs
* Fuse rating: 40A x 2
* Requires 4-gauge power and ground leads 80 amp fuse recommended, wiring and hardware - Not included with amplifier
* 14-11/16"W x 2-5/16"H x 9-5/8"D
Features:
*RMS Power
*Peak Power
*Tri-Way capable
*Preamp outputs
*Two 40-amp fuses
Features:
* Class D design
* Preamp outputs
