Sold FS:*Kenwood*Planet Audio*MDCA*
VarsityBumper
1/1 DouBLe L
Still have these few things waiting to sell.
First Off- 2 Kenwood 12's
I have had these for 5months
One saw power for 2months(200rms)
While the other had power on it for 4months(200rms)
Cosmetically-I'd Rate them a 7 out of 10 from surface scratches and 10 out of 10 for being able to perform
  • 12" Single 4 ohms Subwoofer
  • Power Handling:
    Peak: 800 watts each sub
  • RMS: 400 watts each sub
[*]Typhoon-type pearl mica injection-molded polypropylene woofer cone
[*]Overlapping ribs on cone surface for improved rigidity and dampened resonance
[*]Double stacked 63.4 oz. magnet structure
[*]4-Layer single 4 Ohm voice coil
[*]High roll urethane foam surround
[*]Extended pole piece and bumped back plate for increased cone excursion
[*]Subwoofer Size 12"
[*]Impedance 4 ohms
[*]Peak Power Handling 800 watts
[*]RMS Power Handling 400 watts
[*]Woofer Surround Urethane Foam
[*]Sealed Box Volume 0.8 - 1.5 cu. ft.
[*]Ported Box Volume 1 - 2 cu. ft.
[*]Sensitivity 93 dB
[*]Frequency Response 25 - 800 Hz
[*]Top Mount Depth 5-5/16"
Cutout Diameter 11"
Second i have a MDCA motor from a Sidewinder
And Last I have a Planet Audio BB650.1 Amp
Had This for 4months and only put power to it once. Tested it last week and it goes into protect with some output.
Includes everything it came with including remote bass knob, manual, and mounting brackets
Looks=10/10
MonoBlock CLASS D Amplifier Max Power (2 Ohms)
900W X 1 RMS Power (4 Ohms) 350W X 1 RMS Power (2 Ohms) 600W X 1 Signal-to-Noise Ratio 102dB Frequency Response 20Hz-250Hz Dimensions: 6-1/2”W x 2”H x 11-5/8”
Prices -
Kenwoods 65 Shipped
S/W Motor 20 Shipped
Planet Audio 50 Shipped
Refs -
bigp(roe)
lil_maniac2(ca.com)
onekrazykeebler(ca.com)
ebay - skydog333
been thinking and i'll even add the type r 12 i have laying around.
its been on 300rms for a month....no scratches, original box, manuals, the works
looks are a 10 and preformance is also a 10
110shipped
i'll get pics up on it tomorrow
VarsityBumper
1/1 DouBLe L
VarsityBumper
Michigan
FLOSSINON24S
