FS: JVC KW-AV71BT Double Din
loudexpedition
JVC KW-AV71BT
Used, works 100% the home button is loose for some reason
$240 shipped i have 52 positive transactions on caraudioclassifieds
on me
Google do it translate what ever i do
306
Hi, if no one here is able to help you figure it out, try over at diyaudio in the car audio section, it is a more technical forum. This is one of...
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
loudexpedition
loudexpedition
San Diego, CA
Louisiana_CRX
    Jun 1, 2024
    May 31, 2024
