JL A6450
6-channel car amplifier # at 14.4 volts: * 70 watts RMS x 6 at 4 ohms (110 watts RMS x 6 at 2 ohms) * 220 watts RMS x 3 bridged at 4 ohms # at 12.5 volts: * 45 watts RMS x 6 at 4 ohms (75 watts RMS x 6 at 2 ohms) * 150 watts RMS x 3 bridged at 4 ohms # differential-balanced inputs # Advanced Rollback Protection System # variable high- and low-pass filter (50-200 Hz, 12 dB/octave) # switchable bass boost on ch. 5 and 6 (0, 6 dB at 48 Hz) # optional wired remote bass boost # Absolute Symmetry™ Class-AB amplifier design # MOSFET power and output stages # preamp-level inputs # speaker-level input with optional converter # 4-gauge power and ground leads and a 60-amp fuse recommended — wiring and hardware not included with amplifier # no onboard fuses — when installing multiple amps in a system, an additional 60-amp in-line fuse between the distribution block and the amplifier is recommended # 18-1/8"W x 2-1/2"H x 9-1/4"D
Been installed since 2011, ran active speakers tweeter/mid up front and mono sub with no issues. Some light scuffs and nicks on the front as it was mounted under a seat. Works as expected without issue.
$150 shipped to the lower 48 to include tracking info upon payment and shipment.
https://imgur.com/JasDzab
https://imgur.com/Gzop6TX
