Used JL Audio G6600 6 channel amplifier
Specs:
* 6-channel car amplifier
* at 14.4 volts:
o 75 watts RMS x 6 at 4 ohms (110 watts RMS x 6 at 2 ohms)
o 200 watts RMS x 3 bridged at 4 ohms (150 watts RMS x 3 at 8 ohms)
* at 12.5 volts:
o 55 watts RMS x 6 at 4 ohms (75 watts RMS x 6 at 2 ohms)
o 150 watts RMS x 3 bridged at 4 ohms (110 watts RMS x 3 at 8 ohms)
* differential-balanced inputs
* Advanced Rollback Protection System
* frequency response: 10 to 25,000 Hz
* variable high- and low-pass filter (50-200 Hz, 12 dB/octave)
* switchable bass boost (0, 6 dB at 48 Hz) on channels 5 and 6 only
* optional wired remote control converts switchable bass boost to fully variable (0-12 dB)
* Absolute Symmetry™ Class-AB amplifier design
* MOSFET power and output stages
* preamp-level inputs
* speaker-level input with optional converter
* preamp outputs
* 4-gauge power and ground leads and a 60-amp fuse recommended — wiring and hardware not included with amplifier
* no onboard fuses — when installing multiple amps in a system, an additional 60-amp in-line fuse between the distribution block and the amplifier is recommended
* 9-1/4"W x 2-1/2"H x 18-1/16"D
Very good shape, used for about 6 months, now switching to a 4 channel instead and getting rid of the other set of speakers. Mounted under the rear seat, so there are very few scratches. There is a small mark on the corner, look at the last picture, it must have rubbed something, not bad at all.
$220 shipped obo. Would trade for some TC9 motors.
Shipping will be USPS Priority.
Specs:
* at 14.4 volts:
* at 12.5 volts:
* preamp outputs
