This is an excellent amp and I really hate to get rid of it, but I am expanding my system. This amp has ran a JL 10w1v2 in my F150 for the last year. It has been very gently used due to the fact that I have two very small children. The times that they werent in the truck it rocked. I am adding a second 10 under the rear seat and now need a bigger amp. Cosmetically it's a 8/10, Functionally 10/10. The day I drove my truck off the lot I took it straight to the stereo shop and had this stuff put in. The installers turned and crammed the amp inside the dash so there are a few mild scratches on the heat sink, and one scratch on the face.
I'm asking $150 shipped
Here are the stats.
* Rated Power: 250 W RMS @ 1.5 ohm-4 ohm (11V-14.5V)
* THD at Rated Power:
* S/N Ratio*: >95dB below rated power
* Frequency Response: 5 Hz - 500 Hz (+0, -1dB)
* Damping Factor: >500 @ 4 ohm/50 Hz
* Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
* Dimensions: 10.25"L x 9.25"W x 2.36"H
* Differential-Balanced Input Topology: (1 pair of inputs)
* On-board Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
* Preamp Output: 2-channel (full-range, LP or HP)
* Bass EQ: variable boost up to 15dB
* Infrasonic Filter: defeatable 24dB/octave at 30 Hz
* Signal-Sensing Turn-On: permits operation without remote lead
* Dual mono speaker output connections: accept up to 8ga. wire
* +12V and Ground connections: accept up to 4ga. Wire
And here are the pics
Here are the stats.
