Sold FS: JL Audio 13w7 with Sealed Prowedge Box
caligirl2k
I have a Top of the Line 2,000 Watt 13.5" W7 Subwoofer Dual 1.5 ohm Voice Coil + Original JL Audio Sealed Prowedge Box CLS113RG-W7 with Grills. Its about a month old. asking $700 + shipping. If local we can arrange pick up. MSRP for more than $1200 I can separate...
Product Description:
13" Sub loaded in a sealed enclosure with cross-bar grill, made for rear-firing (3 ohm final impedance)
Power Handling:
1000 watts RMS
W-Cone™ Design: A unit-body cone assembly that delivers astonishing cone stiffness with minimal mass
Highly Linear, DMA Optimized Motor System
Ultra-Long Voice Coil
OverRoll™ Surround: Utilizes space wasted in conventional designs to maintain cone area while permitting a large surround.
Elevated Frame-Cooling
Radially Cross-Drilled Pole-Piece
Floating Cone Attach Method (FCAM™)
Plateau-Reinforced Spider Attachment
Huge Diameter, Progressive-Roll Spider 
Co-Extruded, Double Lead-Wires
Massive, Forced-Air-Cooled Aluminum Alloy Frame
Sealed Compact Enclosure Design
Rock-solid V-groove MDF Construction
Finished in high-grade black carpet with a gloss-black laminate front baffle trim
3 Solid Brushed Aluminum Rods for Woofer Protection
Rear-firing Design
Net weight: 103.2 lbs.
3 ohm Impedance
Dimensions: 22.5"L x 18.25"W x 18.05"H
Subwoofer Specifications:
Subwoofer Size: 13"
Dual Voice Coil: N/A
Impedance: 3 ohms
Peak Power Handling: N/A
RMS Power Handling: 1000 watts
Woofer Surround: OverRoll™ Design
Woofer Composition: N/A
Sealed Box Volume: N/A
Ported Box Volume: N/A
Sensitivity: 86 dB
Frequency Response: N/A
Xmax (millimeters): 32 mm
Top Mount Depth: N/A
Cutout Diameter: N/A
http://mobile.jlaudio.com/products_enclosures.php?menu=5&prod_id=304
http://www.crutchfield.com/S-uN1u7XFxgFB/App/Product/Item/Main.aspx?i=136S113R7
Hmmmm, just signed up on this site to sell a $700 item and only has stock pictures. My scam radar is going off!
Those aren't stock picks. You can paypal with a credit card. If you don't recieved item. File a charge back. You right, you can never bee to careful buying stuff from an online forum. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
a lot easier said then done and those are the stock pics.
caligirl2k
caligirl2k
Pasadena, Ca
caligirl2k
