Sold Fs: Jl 500/5
acubsfan
Cubs Fan
I have a JL 500/5 for sale. Used but in really good condition. I have tons of pictures so you can decide for yourself.
Other than the normal wear and tear and some surface scatches on the bottom side, there is one noticable scratch on the top side which is displayed clearly in several of my pictures. Overall this thing is in really good condition in my opinion and is working great. I just pulled it out of my car as I am now going to be running my setup with two Eclipse amplifiers (XA4000 and XA5000).
I have all solid refs to date just check my sig if there are any concerns. Let's say $325 shipped and pp included for this amplifier. I almost always get items in the mail USPS priority within 24 hours of cleared payment in paypal so let's get this thing sold. Need the dough to buy a new softball bat. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
what are the specs?
Specifications:
* Front Channels: 100W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
* Rear Channels: 25W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
* Subwoofer Channel: 250W RMS @ 1.5 ohm-4 ohm (11V-14.5V)
* THD at Rated Power:
* S/N Ratio* (F&R): >108.5 dB below rated power
* S/N Ratio* (Sub): >95 dB below rated power
* Frequency Response (front and rear): 5 Hz-30 KHz (+0, -1dB)
* Frequency Response (sub channel): 5 Hz-500 Hz (+0, -1dB)
* Damping Factor (front and rear): >200 @ 4 ohm/50 Hz
* Damping Factor (sub channel): >500 @ 4 ohm/50 Hz
* Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
* Dimensions: 19.7"L x 9.25"W x 2.36"H
Features:
* Differential-Balanced Input Topology: (3 pairs of inputs)
* Front Crossover: Fully-variable (50 Hz-5 KHz), selectable-slope BP or HP (12 or 24 dB per octave)
* Rear Crossover: fully-variable (50 Hz-5 KHz), selectable-slope HP (12 or 24 dB per octave)
* Sub Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
* Preamp Output: 2-channel (full-range or LP)
* Bass EQ: Variable boost up to 15dB. Remote bass boost control optional.
* Infrasonic Filter: defeatable 24dB/octave at 30 Hz
* Left minus Right Ambience Circuit: ambient effect for rear channels
* Front and rear speaker output connections: accept up to 8ga. wire
* Dual mono subwoofer output connections: accept up to 8ga. wire
* +12V and Ground connections: accept up to 4ga. Wire
Specifications:
Features:
What he said. Thanks for posting those.
acubsfan
Cubs Fan
acubsfan
Shakopee, MN
acubsfan
