Sold FS: JL 12w7 + HO Box!!
mxer69
1. Product:
JL 12w7 + H.O. Box
2. Specs:
Free Air Resonance (Fs): 27.2 Hz Electrical “Q” (Qes): 0.514 Mechanical “Q” (Qms): 7.807 Total Speaker “Q” (Qts): 0.482 Equivalent Compliance (Vas): 2.33 cu. ft. / 66.0 liters One-Way, Linear Excursion (Xmax)*: 1.15 in. / 29 mm Reference Efficiency (no): 0.249% Efficiency (1W/1m)**: 86.2 dB SPL Effective Piston Area (Sd): 84 sq. in. / 0.0542 sq. m. DC Resistance (Re): 2.47 ohm Nominal Impedance (Znom): 3 ohm Thermal Power Handling (Pt): 1000W Driver Displacement: 0.14 cu. ft. / 4.0 liters Net Weight: 45 lbs. / 20.4 kg
3. Description/Condition:
Great condition but can't fit in the cube :/
Box must either with the sub or before. Will not sell the sub first.
I'm in Charlotte, NC and can meet you (if reasonable).
And I've got a ton of references that can be found under the same username on ca.com
4. Price: :
$550 picked up
5. Pictures:
can be found at JL 12w7 + H.O. Box - Car Audio Classifieds
More pics:
mxer69
mxer69
DC
mxer69
