Sold FS: JBL GTO 12, OZ ME 15, Alpine CDE-102, Dayton HF 8 Subs, EXILE AUDIO XPE 12
bjayjr5679
Father of Three
JBL GTO 1214
BNIB 10/10 condition
$85 Shipped OBO
SPECS:
• 12" Single 4 ohms Grand Touring Die-Cast Series Subwoofer
• Power Handling:
o Peak: 1400 watts
o RMS: 350 watts
• Impedance: Single 4 ohms
• Polypropylene cone woofer
• Rubber surround
• Tinsel wire protector
• Die-cast aluminum basket
• 2" Single 4 ohms voice coil
• Frequency response: 23-400 Hz
• Sensitivity: 90 dB
Minimum Sealed Box Volume 1.0 cubic feet
Maximum Sealed Box Volume 1.0 cubic feet
Minimum Ported Box Volume 1.75 cubic feet
Maximum Ported Box Volume 1.75 cubic feet
Specs form JBL
http://www.jbl.com/resources/Brands/.../GTO1214TD.pdf
OZ ME 15.4d
$135 Plus Shipping (kind of firm on this one because of me double boxing and peanuting this thing up to make for secure shipping)
Mint not in original box
9.5/10 (just cause its used)
Description: The Oz Matrix Elite series of subwoofers represent Oz Audio's obsession to create the ultimate in subwoofer technology. Every aspect of these subwoofers was designed and scrutinized to ensure maximum SPL and the ultimate in sound quality.
· Diameter: 15"
· Impedance: Dual 4 Ohm
· Power Handling (RMS/Peak): 700W / 1400W
· Sensitivity (1W/1M): 86dB
· Frequency Response: 18-500Hz
· Xmax (mm): 25mm
· Fs (Hz): 27Hz
· Mounting Depth: 8 1/16"
· Mounting Diameter: 14 1/8"
· Voice Coil Diameter: 2 1/2"
· U-Turn Hyper Surround composed of dense UV treated foam, shaped into a nonstandard profile representing a "U". This design accomplishes two goals: The cone's surface area is maximized, therefore maximizing SPL output. Additionally, the surround's taller profile allows for increased Xmax and linearity.
· Three layer cone comprised of two layers of braided glass fiber with a layer of nomex sandwiched in between to create a material which is extremely rigid, yet remarkably lightweight.
· Competition style aluminum die-cast basket
· Underlap cone attachment
· The spider assembly comprised of blended cotton and nomex, called conex, results in a materail that is flexible like cotton, yet has the tensile strength of nomex. Additionally, the lead wires are interwoven into the spider to eliminate breakage during extreme SPL excursion.
· Dual wound, 2.5-inch voice coils on a glass fiber former.
· Cross-Vent intercooling through the basket to allow the voice coils to remain cool during operation. 8. 150 ounce triple magent motor assembly
· Custom engraved chrome backplate with Oz Audio logo engraved. Additionally, the backplate has a vented radius.
· Extended Coil Windings for Increased Xmax
· Double Sided Engraved Rubber Gasket
· Protective Rubber Magnet Sleeve
· Specially Designed Vacuum Formed Dust Cap
· Nickel Plated Push Terminals
(2) Dayton RSS210HF-4 8" Reference HF Subwoofer 4 Ohm
BNIB
135 Shipped
Specifications:
* Power handling: 280 watts RMS/500 watts max
* VCdia: 2"
* Le: 0.68 mH
* Impedance: 4 ohms
* Re: 3.3 ohms
* Frequency range: 27 - 1,000 Hz
* Fs: 28 Hz * Magnet weight: 50 oz.
* SPL: 86.5 dB 2.83 V/1m, 83.5 dB 1W/1m
* Vas: 1.14 cu. ft.
* Qms: 3.08
* Qes: 0.60
* Qts: 0.50
* Xmax: 9 mm
* Dimensions: Overall diameter 8-1/2", Cutout diameter 7-1/4", Depth 4-3/4".
· Extensively vented motor eliminates compression and allows quiet excursion
· Lightweight black anodized aluminum cone for rigidity and lower moving mass
· Suitable for sealed or vented enclosures
· Triple shorting ring motor for ultra-low distortion
· 2-layer coil for reduced back EMF
· Highest quality materials throughout for long-lasting performance
bjayjr5679
Father of Three
bjayjr5679
Columbus, Ohio
bjayjr5679
