Sold FS: iPaul DM2000
biker911
I have this iPAUL DM2000 amp that I got on a trade on here that I want to get rid of. I am looking for $400 (or best reasonable offer) shipped. I will post pictures later on when I get home. I have the original box for it, the velvet bag for the amp, and gain/phase remote for it.
Here are the pictures as promised:
Powered up....
Or, heres a deal, if you are willing to order a Sundown SAZ1500 ($350) from DB-r.com and have that shipped to me you can have the iPaul. So basically a trade....
6
Technical Data
Peak output power 1 x 2000 Watt
Output power 1 x 360 Watt RMS at 4 Ω
Output power 1 x 730 Watt RMS at 2 Ω
Output power 1 x 1000 Watt RMS at 1 Ω
Total distortion factor THD+N 0.04 % (100 Hz /1 Watt)
Signal-to-noise ratio S/N >90 dB/A-weighting
Frequency range –3 dB 10 Hz – 250 Hz
Input sensitivity line input 250 mV – 6 V
Connection impedance 1 Ω, 2 Ω or 4 Ω possible
Damping Factor >160 at 4 Ω, Strapping Mode >700
Operating voltage 11 V – 16 V DC
Max. input power/ Peak current admission 90 A/155 A
Efficiency 85 % with 14.4 V DC
Short circuit protection / Overloading Immediate switch off
Temperature monitoring heat sink 80°C switch off
Soft start-muting on/off 1 sec. signal delay
Dimensions: W x H x D 415 x 60 x 250 mm
Weight 5,5 kg
Certification E11 10R-024179
Active Controls:
Low pass 50 Hz - 250 Hz infinitely variable, 24 dB/Oct.
Subsonic Filter 15 Hz - 50 Hz infinitely variable, 24 dB/Oct.
Bass Boost 45 Hz, up to +12 dB switchable
Phase shifter 0 – 180° infinitely variable
Remote control Phase shifter and gain infinitely variable
biker911
biker911
Baltimore
Carbon
