FS: Infinity kappa one mono amp used
Radiospank
Infinity kappa one
Good condition used:
Kappa Series Class D Mono Subwoofer Amplifier
RMS Power Rating:
4 ohms: 500 watts x 1 chan.
2 ohms: 800 watts x 1 chan.
Max power output: 1600 watts
MOSFET power supply
3 LED indicators (2 power, 1 protect)
Bass Boost (0-12 dB)
DirectFET transistors increase power output and overall efficiency
Non-Stop Thermal Protection (The amplifier will gradually reduce output to cool the amplifier down instead of shutting it off if it overheats)
Dynamic Bass Optimization (DBO): Fine-tune the bass in your system to optimize performance. The frequency control also acts as a subsonic filter
Protection Circuitry (DC output, over/under voltage, short circuit)
Heavy duty aluminum alloy heatsink for supreme heat dissipation
Preamp RCA outputs
1 Channel operation
RCA level inputs
Screw terminals
Variable high-pass filter (10-80 Hz, 12 dB/octave)
Variable low-pass filter (32-320 Hz, 12 dB/octave)
Subsonic Filter (24 dB at 15 Hz)
CEA-2006 compliant amplifier
Frequency response: 20-320 Hz
Dimensions: 13"L x 7-1/16W x 1-3/4H
Price:180
Free US only
Has a scuf mark on corner and scratch on side. Never been abused just scuffed from mounting
Radiospank
Radiospank
los angeles
fannin88
