FS: Hertz EP1D
shiipseki
Hertz EP1D
I have a slightly used Hertz Ep1D
# Output Power (RMS):
# 400W x 1 @4-ohm
# 750W x 1 @2-ohm
# 1000W x 1 @1-ohm
# HP Link mode RMS Power:
# 1500W x 1 (4-ohm - HP LINK)
# 1700W x 1 (2-ohm - HP LINK)
# Low Pass Filter: 25 - 250Hz @24dB/Oct (L+R)
# Subsonic: By-pass / 10 - 50Hz @24dB/Oct
# Output Phase Selector: 0/180 Degress
# EP LINK mode: Master/Slave
# Bass Boost: 0-18dB @50Hz
# Output Filter: Continuous 0-180 @12dB/Oct
# T.H.D. (100Hz @4-ohm): 0.15%
# Bandwith (-3 dB): 10 - 250Hz
# S/N Ratio (A weighted @1V): 100dBA
# Damping Factor (100Hz @4-ohm) >100
# Pre-In sensitivity: 0.3-5Volts
# Pre-In impedence: 15 kohms
# Speaker-In sensitivity: 1.4-24Volts
# Speaker-in impendence@ 5kOhms
# Load impendence: 4-1Ohms
# Power supply voltage: 11 - 15Volts
# Idling current: 2A
# Idling current when off: 0.04mA
# Consumption @1ohm, 14.4VDC: 56A
# Remote In: 6-15 VDC - 1mA
# Remote Out: 12 VDC - 50mA
# Automatic Turn On/Off with speaker in
# Fuse: 3x40A
# RVC (A-remote Volume Control - OPTIONAL)
# Dimensions (mm): 240 x 350 x 54
250 Shipped
wat kind of wire n how much? wat is skar? nt on sub & amp //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
shiipseki
shiipseki
LA, CA
shiipseki
vegang
vegang
