Sold FS/FT Sundown 100.2, 2 Nightshade 18s
2000LaDe
alright im about to start my big build and need to get rid of some of the things i have laying around that i decided not to go with. prices are firm unless buying all at once. so dont waste my time. i dont mind having audio laying around like i usually do.
MINTY Sundown 100.2 Sold
# 100 x 2 watts @ 4 ohms
# 200 x 2 watts @ 2 ohms
# 400 x 1 watts @ 4 ohms bridged
# Damping Factor > 200 @ 4 Ohms
# 0.2v - 6v adjustable input sensitivity
# 10 Hz - 40,000 Hz Frequency Response
# Channel Separations: 75 dB
# > 90 dB S/N Ratio
# 4-Way Protection Circuit (Thermal, Overload, Speaker Short, and Over Current)
# Selectable HP / LP / FULL crossover
# 50 Hz - 500 Hz adjustable 18dB Low-Pass Crossover
# 50 Hz - 500 Hz adjustable 18dB High-Pass Crossover
# 0 - 18 dB adjustable bass boost with 45 Hz center frequency
# Wired Remote Control unit included
# 3x 20 Amp Internal Fuses
# 13.375" L x 9.9" W x 2" H
1 Sundown Nightshade 18 - 250 + shipping
# 3" Diameter 8-layer flat-wound Aluminum Wire Voice Coil
# High Temperature Aluminum Voice Coil Former
# 1500-Watts RMS Power Handling
# Over 2 inches peak to peak excursion
# Wide, triple-layer foam surrounds for high excursion
# Extremely strong paper cones w/ stiffening disc
# Thick poly dust caps
# Cast Aluminum 12-spoke basket with cooling vents
# Triple Stacked 1" x 9" magnet slugs for high motor strength
T/S D1 **:
RMS: 1500
Z: 2 ohms
Re: 2.09
Fs: 35 Hz
Qms: 9.9
Qes: 0.58
Qts: 0.53
VAS: 82.88 L
BL: 18.98 NA
0these things might have an hour of play on them. they are dual 1's.
local pickup would be preferred on the 18s but have original shipping containers so its all good.
no sorry evan never cared for the sound of a DD. i already have a couple 4 channels laying around dont really need another one either.
i might be interested in some 1/0 wire, ring terminals. spools of 12 awg speaker cable. copper bussbars. rolls of 4 awg, rolls of 8 awg....
1 SOLD, 1 Left.
i also have another 18 that i just glued a new dust cap on and i didnt do the greatest glue job its kinda messy looking but i will let it go for 250+ shipping if anyone is interested.
both subs sold. still have this nightshade 18 dual 1 for sale. dustcap was making a noise so i glued a new one on it. this sub actually has less play time than the 2 that just sold.
2000LaDe
2000LaDe
Lafayette, IN
RG1
