RE Audio REX 10 Dual 4 Sub
This sub is about a month old, I bought it, mounted it and decided on going with an 8" instead of a 10" in my single cab truck. This sub has never seen power and I have the original box, packing foam, and instruction manual.
10" Dual 4 ohm REX Series Subwoofer
Power Handling:
RMS: 175 watts
Impedance: Dual 4 ohm
Mica filled poly cone woofer
Santoprene rubber surround
Pressed steel basket
FEA Optimized motor structure
Linear Conex spiders
Rubber gasket
High temperature 8-layer copper voice coil
Powerful, single stacked magnet
Sensitivity: 84.7 dB
Mounting Depth: 5"
Authorized Internet Dealer
1-year Manufacturer's warranty
REX 10D4" T/S Parameters:
Electrical Q Value (Qes): 0.39
Mechanical Q Value (Qms): 4.37
Total Speaker Q Value (Qts): 0.36
Free Air Resonance (Fs): 21.5 Hz
Equivalent Compliance (Vas): 75.6 liters
One-Way, Linear Excursion (Xmax): 12 mm
Efficiency (SPL 1W/1m): 84.7 dB SPL
Effective Piston Area (Sd): 322 cm2
DC Resistance (Re): 3.2 ohm
Nominal Impedance (Znom): Dual 4 ohm
Thermal Power Handling (Pe): 175 W
Force Factor (Bl): 15.4
$42 shipped ($40 + fees), or trade for the 8" version.
Power Handling:
RMS: 175 watts
Rubber gasket
Mounting Depth: 5"
