Two 15" Alpha subs dual 2 and upgraded to take 2000wrms a piece and have Heavyweight soft parts!!
Primarily Looking for 15's or 18's! Omegas is what I really want or TC3000's, 5200's, 5400's, ,Death Penalty, Warden Series, ooul r Heavyweights.
Would also consider 4 Alpha MAX 12's and can add cash on any deal if needed.
$650 shipped in CON US OR BEST OFFER!!!!!
SO if you dont like the price MAKE AN OFFER!!
Subs work FLAWLESSY and sound great and still look very close to NEW.
There are two issues with them though and I will sow the issues below in pics as well as coil readings from today.
One sub has a very very small hole in the surround from mounting the sub but you CANNOT SEE unless you are 3 inches away from it as it is very small. I fixed this correctly and used 100% silicon on the inside of the surround and the sub plays absolutley fine just like it should.
Sub #1 Coil 1
Sub #1 Coil 2
Sub #1 has the small hole in surround that is fixed as you can see below. 1st pic is top and second pic is where I put silicone on the inside of the surround just to make sure it was sealed up correctly.
Sub #2 coil 1
Sub #2 coil 2
Sub #2 basket crack (Epoxy would probably seal this right back up if you had to but I did not even notice it until I took these out of their previous enclosure as there was no Issues with the performance in either enclosure.)
The rubber surround holds the little piece with the crack in place and is not even visable unless you pull the rubber surround back.
Pics of subs when mounted as you will see by these photos they look brand new.
Sub #1 Coil 1
Sub #1 Coil 2
Sub #2 coil 1
Sub #2 coil 2
