I need to get rid of these to get some bigger ones so they're priced to sell. Nothing wrong with them at all and they are in PRISTINE condition. The ONLY trade I will accept is a 3000+ watt amp that will do it at 2 or .5 ohms. I prefer the 2 ohm load but I will compensate.
Orion 2500d $360 shipped, firm (+ 3% if using PP) SOLD!!!
Specs.
* 1 X 1200 @ 4 Ohm
* 1 X 1700 @ 2 Ohm
* 1 X 2500 @ 1 Ohm
* Selectable 12/24 dB/octave variable low-pass filter
* Intelli Q bass optimization circuit and remote gain option
* Separately adjustable, selectable variable high-pass filter with proprietary Copy/Master control circuit for RCA outputs
* Copy/Master feature supports gain and crossover adjustment matching in multiple amp
* Switchable phase invert function
* Heavy gauge direct-wire high current satin finish power and speaker terminals
* Dimensions: 27.2" x 10.5" x 2.3" (691mm x 267mm x 58mm)
Orion 8004 $200 shipped, firm (+ 3% if using PP) SOLD!
Specifications:
* Power Output:
o 4 x 100W @ 4 Ohms
o 4 x 200W @ 2 Ohms
o 2 x 400W @ 4 Ohms
* Signal Processing:
o Variable Low-Pass 20Hz to 3kHZ
o 16dB of boost with INTELLi Bass
o >Selectable AUX out
* Fuse Size: (1) 100 MAXI
* Dimensions: 23.9" x 10.5" x 2.3" (607mm x 267mm x 58mm)
Specs.
* 1 X 1200 @ 4 Ohm
* 1 X 1700 @ 2 Ohm
* 1 X 2500 @ 1 Ohm
Specifications:
* Power Output:
o 4 x 100W @ 4 Ohms
o 4 x 200W @ 2 Ohms
o 2 x 400W @ 4 Ohms
