Sold FS/FT Kicker JBL Infinity Kenwood
stuckinok
Sick My Duck
First Kicker SSMB6 Midbass Drivers that have never seen power Asking 70shipped retail at 195.99
RMS Power Range : 8-125 Watts
Peak Power Handling: 250 Watts
Low Frequency response: 30 Hz
High Frequency Response: 500 Hz
Impedance: 4 Ohm
Tri-Tech cone (sandwiched foam, polypropylene, and woven carbon fiber)
Santoprene rubber surround
low profile stamped steel basket
spring-loaded nickel-plated terminals accept heavy-gauge speaker wire
free-air capability flush-mount depth: 2-1/16"
Sensitivity: 88 dB
JBL P25t Power series Tweeters BNIB Asking 60shipped retail 139.99
Power Handling, RMS: 60 Watts
Power Handling, Peak: 180 Watts
Frequency Response (ᄆ3dB): 2.5kHz - 23kHz
Sensitivity: 90dB
Mounting Depth: 1-3/16"
Cut-Out Diameter: 1-3/4"
Impedance: 4 Ohms
ユ Pure-titanium edge-driven dome tweeters - These are not commonly used miniature cone tweeters, but full edge-driven domes like those found in high end home audio loudspeakers. The benefits of this full edge-driven topology are reduced distortion at high output levels and superior integration with the mid/woofer.
Kenwood KFC-P707 6.5 component system used but tweeters are blown but crossovers and mids are 10/10 for function and looks asking 60shipped retail 220.00
6-3/4" titanium-coated poly woofer with rubber surround
UFLC dome tweeter with multiple mounting options
non-uniform thickness surround for balanced woofer movement
external 4.5 kHz crossover (6 dB per octave, low-pass; 18 dB per octave high-pass) with three different tweeter attenuation levels
power range: 8-65 watts RMS (280 watts peak power)
frequency response: 30-35,000 Hz
sensitivity: 92 dB
top-mount depth: 2-1/4"
last i have 4pairs of brand new Infinity Reference crossovers asking 18shipped a pair
75wrms
2-way external crossover network (18 dB/octave, 3,500 Hz high-pass and low-pass
as for trades i need a set of midranges that will handle atleast 125wrms and i need a Kicker ZX650.4 or a 4champ that will do 100x4 or more and a set of 4ch RCAs around 3feet long
Lots of refs and i will post pics later tonight
Thanks
Jose
Hey bro,Do you have pics of the Kicker midbass drivers ?
dang wife took the SD card out the camera and now i cant take pics till the morning but are you really interested in them //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
stuckinok
Sick My Duck
stuckinok
Rio Rancho, NM
stuckinok
