Sold FS: Entasi Audio 12" Subwoofer - TC9 Motor -
bushtree
Hey guys,
This is my last one. It is a truely amazing subwoofer. I perfered it over my RE SE in both output and SQ.
Anyways..
Entasi Audio 12" Subwoofer - SOLD
-Dual 2ohm
-TC9 motor
-24mm Xmax
check out more about the sub at http://forum.carstereos.org/f-car-audio-49/t-entasi-12-review-extended-listening-38174/?highlight=entasi
Truley an amazing subwoofer..
T/S Parameters
Qts - .313
Qes - .349
Qms - 3.00
FS - 24hz
Vas 73.32 l
Mms - 201.9
Cms - 216.6
Bl - 17.93
SPL - 86.49
X-max 24mm
Power Rating: 500-800W RMS
Dual 2-ohm VC
Depth ~8”
Sd – 489 cm^2
**** good sub...
T/S ParametersQts - .313
Qes - .349
Qms - 3.00
FS - 24hz
Vas 73.32 l
Mms - 201.9
Cms - 216.6
Bl - 17.93
SPL - 86.49
X-max 24mm
Dual 2-ohm VC
Depth ~8”
Sd – 489 cm^2
**** good sub...
^ Yep, RMS is 600-800W however the motor can handle 1000+ but it will bottom out so 600-800.
It sounds plenty good with only 450watts though //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Hey, I was looking at some of your other post on this sub. You say it needs a
1-1.5 cu ft box? I ran the specs though WinISD and it shows a .6 cuft for a.71 Qts. Are the specs above correct?
bushtree
bushtree
San Diego
Big Dee
