FS: Eclipse DA7122, 1000 @ 2ohm
its_bacon12
I4NI
Eclipse DA7122 Class D
Looks great, works perfect. Has some sticker residue on the heatsink near the power input from being a display model.
Manual: http://www.cartoys.com/cartoy/pdfs/eclipse_amp_manual.pdf
Someone else's thread with internal pics: http://www.caraudio.com/forums/amplifier-classifieds/522648-eclipse-da7122.html
$160+shipping
+shipping via FedEx
Does it get hot and is it 1 ohm stable?
No it isn't one ohm stable. But it's an Eclipse. It probably puts out more than rated and very efficient.... Why stop sound laws? You one of those idiots that likes to bump your shlt through residential neighborhoods?
What are the exact specs for the amp, I cant open the manual. And no, I am very respectful with my system but down here its ridiculous they ticket you anywhere, even on the highway.
I'll copy/paste, and no it is not 1 ohm stable. No reason for it to be.
13.8V POWER SUPPLY
Max. Power Output 2000W × 1ch
1Ω Not Supported
Power Output -1000W -500W
THD @ Rated Power @ 1Ω Not Supported Not Supported
@ 2Ω 0.007% 0.007%
@ 4Ω 0.005% 0.005%
Input Voltage Neg Gnd 10.8 ~ 16V
S/N Ratio >120dB
Freq. Response 4 ~ 3000Hz
Crosstalk >80dB
Slew Rate 20Vμs
Damping Factor >1000
Input Sensitivity 0.2 ~ 8V
Max. Current Consumption 100amps
CHANNELFLEX CROSSOVER
Amp Crossovers Lo-Pass 12dB/octave 50 ~ 200Hz
Subsonic 18dB/octave Defeat 1 ~ 60Hz
Pre-Amp Output Hi-Pass 12dB/octave 50 ~ 200Hz
Dimensions (W × H × D) 15.75˝ × 2.05˝ × 11.85˝
its_bacon12
I4NI
its_bacon12
Norwalk CT
Flex68
