BNIB Soundstream DTR1.1700
KnightWhoSaysNI
BNIB-
Soundstream D-Tower Series Monoblock Class D Car Amplifier
RMS Power Rating:
2 ohms: 1100 watts x 1 chan.
1 ohm: 1700 watts x 1 chan.
Full MOSFET Power Supply
The worlds first vertical automotive stereo amplifier
Double side PCB and SMD components
LED power (green) and protect (red) indicators
Monoblock operation
Gloss black finish w/ brushed accents
Dash mounted remote gain control
3-Way System Protection circuitry (thermal, short, impedance)
Heavy duty aluminum alloy heatsink for extreme heat dissipation
Nickel-plated RCA level inputs
Nickel-plated screw terminals
Variable high-pass filter (10-50 Hz)
Variable low-pass filter (40-220 Hz)
Subsonic Filter (10-50 Hz)
Bass boost frequency: 30-90 Hz
Bass boost level: 0-12 dB
Signal-to-noise ratio: >85 dB
THD (Total Harmonic Distortion): 0.5%
Damping factor: >200
Frequency response: 10-220 Hz
Dimensions: 14-5/8"L x 3-5/16"W x 7-1/2"H
4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
$195
Shipping included
Sound Stream Said they can be ran at .5ohms, 4ohm they are at 750watts which isn't listed on their site.
I actually have my dtr 17001 sitting in the car running at 4ohms, actually sounds cleaner than my memphis pr10001.. but only running it at 4ohms and was running the pr10001 at 1ohm.. bump for good amp tho
KnightWhoSaysNI
KnightWhoSaysNI
Oregon
bjizl
