Sold FS: DLS Ultimate Iridium 6.3i 3-way component frontstage
countdown
NJ
Hello everybody, up for sale is my DLS 6.3i frontstage. They work flawlessly and are in excellent cosmetic condition. The Iridium need no introduction- always stellar reviews. Grills and crossovers are included.
$425 shipped. Located in NJ for those interested in local pickup.
Feedback - My screenname is 02maxxxSE (click) on Maxima.org.
Ultimate series Iridium 6.3 is a 16,5 cm (6,5") 3-way component. The 6,5" driver uses a cone of cated non-press paper. Improved model with die cast basket.
- The midrange is Iridium 3 (3", 75 mm) mid dome speaker with a rear chamber.
- Hybrid ferrite/neodymium magnet system.
- Three inch voice coil.
- Filter boxes with selectable tweeter and mid level in three steps.
- 28 mm silk dome tweeter Iridium1i.
- Grilles are included.
Specifications
Woofer size 16,5 cm (6,5")
Midrange size 75 mm (3")
Tweeter IR1i, 28 mm (1,1") tweeter in metal housing
Power handling capacity 100 W RMS / 160 W max
Impedance 4 ohm
Frequency range 50 - 25.000 Hz
Sensitivity 91 dB (1W/1m)
Crossover Box filter LP12dB / HP 6, LP 6 dB / HP 6 dB
Crossover point (Hz) 400 Hz / 5500 Hz
Size of filter box 145 x 85 x 45 mm ( 5,71 x 3,35 x 1,77")
Outer diameter of woofer Woofer: 165 mm (6,5") Mid: 120 mm (4,72")
Magnet size 85 mm (3,35") Hybride ferrite/neodymium
Mounting depth Woofer: 65 mm ( 2,56") Mid: 35 mm (1,38")
Mounting hole Woofer: 140 mm (5,5") Mid: 95 mm (3,74")
i have the same exact set i am going to be installing. how did ya like em? is there a breakin period?
Loved them. Nice and natural sound. Don't recall any significant break-in period, although I did take it easy for the first 50hrs.
countdown
countdown
NJ
countdown
michigan born
    May 14, 2026
michigan born
    May 14, 2026
